I found the follow info on this site about changing the 2824 PLL for the 2816, i dont have a 2816 only a 2814 which according to the specifications its the same PLL, however when i changed it the set was stuck on one channel (received and transmitted on the one channel so PLL must be ok) will the 2814 work or do i have to use a 2816.
Also, whats a super slide diode ? never heard of them before.
Thanks
President AR144 high band Upd2816 mod ?
Re: President AR144 high band Upd2816 mod ?
Sorted now
The upd2814 does work, but requires +5v to the Binary programable inputs rather than 0v hence why it was stuck on ch40, modified the channel selector slightly and bingo works fine.
