Radio Make and Model: northstar / galaxy 44v
PCB Number: EPT360014B
Test gear available: watt/swr meter, multimeter, external freq counter
Symptoms: no tx power
What is working: audio through pa, can hear on close radio
What has been tried: changed driver 2sc2166
Did it suddenly happen ?: yes
TR43 final 2sc2312
b....c.....e
0 / 3.8 / 0 rx
-7 / 3.8 / .15 tx
tr44 driver 2sc2166
b.....c.....e
0 / 3.8 / 0 rx
0 / 3.3 / .15 tx
tr45 predriver
b.....c......e
0 / 0 / 0 rx
.80 / 8.3 / 1.2 tx
northstar/galaxy 44v no power
Re: northstar/galaxy 44v no power
What's the voltages on SSB, as you have not said what mode the voltages are for you've given.
The Base voltage for the driver and final on SSB should be no more than 0.7v and the collector voltage about 13v.
The radio is am/fm only, tested on am
