Radio Make and Model: Connex 3300 hp
PLL Number: 145106p
Test gear available: frequency counter and test meters
Symptoms: off frequency on some channels
What is working: The radio is working normally on channels 1 through 25, but 26 thorugh 40 takes you into the 28 mhz range.
What has been tried: changes out the pll
Did it suddenly happen ?: no
Anything else that may be of help?: On the band just below regular 40, all channel frequencies are off.
connex 3300 hp loss of some frequencies
knockahoma1
Re: connex 3300 hp loss of some frequencies
Try adjusting the VCO slightly to see if you get any more channels than you've got, somebody might have been playing with it, like they do.
