Radio Make and Model: cobra 146 gtl
Test gear available: freq counter, 1040 cb service master, multi-meter.
Symptoms: scratchy noise from recieve audio and when touching cb thru the speaker. Audio is fuzzy.
What is working: everything
What has been tried: external speaker
Did it suddenly happen ?: no
Anything else that may be of help?: no
Cobra 146 gtl scratchy recieve
tejanodrum
- First Name: herb
Re: Cobra 146 gtl scratchy recieve
Try changing the electrolytic capacitors around the audio IC. Two of them are only 10v but change C132 first 330uF @ 16v.
Electrolytic capacitors dry out with old age and cause problems.
