Ham International Concorde 2
turismo05
Post by turismo05 »
Hi all,
Can any one help with getting my old Concorde II back in order?
The RX is fine on all channels
The problem is the TX on FM/AM.
USB/LSB Seem o.k
I have it connected up to a SWR meter and ariel.
On FM when TX the SWR meter not move at ALL
On AM the SWR meter move a small amount when whistling into mike
On SB Whistling into mike SWR meter rockets off the scale.
Now I have a handheld scanner and when set to the correct channel on
FM and AM I can hear myself at short range.
Anyone any ideas about my problem, any help much appreciated. Would
really like to get this rig 100% again.
Thanks
Tony
timrim
Heavy User
Heavy User
Post by timrim »
I can say with about 99% certainly that the final has blown.
The Defpom
Site Admin
Site Admin
Post by The Defpom »
It sounds more like the regulator may have failed, I think it was Q36, a 2SD device.
It could also be the big adjustable resistor that is mounted inside the chassis, I have known those to fails also.
Re: Concorde 2 no TX power.
I do not think it is Q36 as it is only used in AM mode.
I think you need to check if there is 13.8 vdc at the collector of Q9 and Q10 in FM TX mode.
If the volts are missing at Q10, check choke L11 that is known to burn up or as Timrim says, it could be a bad final but I would test it first, as there are other faults, which can cause you to have low TX power.
turismo05
Post by turismo05 »
Thanks for the replies guys
I checked to collectors of Q9 and Q10 in FM tx and 0 volts
In AM around 5 Volts
In USB/LSB I get 13.5 volts
All help much appreciated
Tony
Please use the Post Subject.
Check the voltage at each side of L11 in FM TX mode, if no volts check the mode switch as you may find a broken wire or a bad mode switch.
Good luck lots of wires around the mode switch.
turismo05
Post by turismo05 »
Rick wrote:Please use the Post Subject.
I have checked and no volts either side of L11 in FM TX mode.
The wiring at the mode switch looks in place, so maybe a faulty mode switch?
Next question... where will I find one of those??
Thanks again for all the help
Tony
Re: Ham International Concorde 2
I may have a new one, I will have a look and let you know.
